It is currently Thu Aug 14, 2025 6:36 pm
PostPosted: Fri Feb 29, 2008 5:11 pm
Well for you guys that have always wanted to build a classical but use the standard Steel string assembly process with a body mold and bolt-on neck will be happy to know I am working on and nearly through with my next edition to the OLF Library of plans Here is a sneak peek and it is drum roll please........
This will be more likely of interest to hobby builders than the typical hardcore Classical builders But none the less it is a way to build a classical with a bolt on in the same process we steel stringers are accustomed to
PostPosted: Fri Feb 29, 2008 5:33 pm
Holy Smokes! TwiLight Zone!
I was just at Bob Garrish's shop (Saint Lutherie) yesterday talking about using/wanting a bolt on neck for a classical. Very nice MP looking forward to getting my little mitts on a set of those!
I think Joshia deJonge also uses this type of construction for her instruments. http://www.joshiadejonge.com
Guitar Building = Continuous Improvement Process
PostPosted: Fri Feb 29, 2008 5:44 pm
Raymund wrote:
Holy Smokes! Twilight Zone!
I was just at Bob Gerrish's shop (Saint Lutherie) yesterday talking about using/wanting a bolt on neck for a classical. Very nice MP looking forward to getting my little mitts on a set of those!
Personally I find nothing wrong with it. I also originally designed a neck block that had hide-able pockets for the bolts and appeared to be a Spanish Heel construction when finish but decided that I might be accused of trying to fool some one into thinking it was Spanish Heel construction and decided I did not even want that to come up.
PostPosted: Fri Feb 29, 2008 8:35 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I think it's a great idea. My first build was a 1937 Hauser clone. Since it was just for me, I adapted the neck
attachment to a bolt-on. Sounds fine, I see no drawbacks.
Gene
PostPosted: Fri Feb 29, 2008 10:56 pm
I am so glad I'm a hobby builder and not a hard core classical builder!
I am planning a Padauk/Cedar nomex double top, double back, laminated sides, sound ports, and hopefully a bolt on CNC classical neck!!
And for the coup de grace...I am using it to play Chet Atkins style finger style!
I wonder if I should post this on the classic guitar forum??? beehive
(running away and ducking for cover...)
PostPosted: Fri Feb 29, 2008 11:45 pm
Michael bro I just want to thank you once again for all that you do for us. To date most of the guitars that I have built have been based on your very fine plans.
Your contributions to this forum are as good as it gets and I am very proud to call you my friend.
[clap] [clap] [clap] [clap] [clap]
PostPosted: Sat Mar 01, 2008 12:03 am
Excellent, Michael. Thank you!
Todd Rose
Ithaca, NY
PostPosted: Sat Mar 01, 2008 7:15 am
thanks, Michael. I have been thinking about making a guitar with a bolt on neck for some time.
Thanks again,
Max
Max Bishop
Brighton, Michigan
PostPosted: Sat Mar 01, 2008 7:49 am
First name: Erik
Last Name: Hauri
State: Maryland
For sure this will get me started on classicals! Can't wait for the final plans!
The member formerly known as erikbojerik....
PostPosted: Fri Feb 19, 2010 9:13 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
Is there a formal OLF plan library? How does one get the OLF plans?
PostPosted: Fri Feb 19, 2010 10:00 am
From Stewmac: http://www.stewmac.com/shop/Books,_plans/Plans/OM-style_Guitar_Plans.html
PostPosted: Fri Feb 19, 2010 10:40 am
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Excellent I'll pick one up, thank you!
PostPosted: Fri Feb 19, 2010 12:03 pm
I am sorry to say that my Classical Bolt-On Neck plan was never picked up by Stewart MacDonald. They only carry my guitar plans. There is not a OLF Classical guitar plan available. When the OLF Library of plans went away in 2008 so did this plan set. The CAD file was on a laptop that was lost during one of my overseas business trips. I have searched my back up and I can not find that file anywhere. Lance and Brock may still have a copy of the PDF I sent them but I do not know that for sure.
PostPosted: Fri Feb 19, 2010 12:04 pm
First name: Richard
Last Name: Gagnon
City: Port Alberni
State: BC
Looking forward to getting my mits on a set of those plans! I've built an SJ from your plans and found them to be an excellent resource. I have a set of Uncle Bob's Dalbergia Granadillo earmarked for that project. Thank you Michael!
edit: Just read your post Michael and checked the date on original post. Sorry to hear that. Sounds like an excellent plan, Stew-Macs(and our)loss.
I think, therefore I am....often confused!
PostPosted: Fri Feb 19, 2010 12:16 pm
hey Guys, there is some good news. While the Cad drawings are lost I have the original printed plan sets on mylar that I can scan into a PDF of both the Classical and Steel String neck plans. If interested PM me
PostPosted: Fri Feb 19, 2010 12:22 pm
Where is the "OLF Library of plans"? I remember seeing it some time ago, but now cannot find it.
PostPosted: Fri Feb 19, 2010 12:23 pm
Gone, bye - bye! gaah
It is no longer. it was done away with back in late 2008
PostPosted: Fri Feb 19, 2010 2:37 pm
First name: Hugh
City: Lake Oswego
State: oregon
Sign me up.
Hugh
PostPosted: Fri Feb 19, 2010 2:43 pm
Hupaand wrote:
Sign me up.
Hugh
I sent a PM
PostPosted: Fri Feb 19, 2010 4:23 pm
I am setting here scratching my head.....5 people have asked about aquiring copies of the plans. 3 directly on this post and 2 by PM. I sent out PMs to all 5 within just a few mins of thier post or PM and that was quite a while ago. All 5 PM are still unread. Not that that is a problem but I am woundering if the PM service is down or somthing idunno
PostPosted: Fri Feb 19, 2010 4:25 pm
Maybe they aren't signed up to get notification of PM's present, and have not noticed.
PostPosted: Fri Feb 19, 2010 4:27 pm
I know 2 of them are. and i told thee other 3 on this post that I sent a PM very shotly after thier post idunno
PostPosted: Fri Feb 19, 2010 5:14 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
Sign me up for a copy of these plans too please Michael.
I just finished my first classical guitar, a Hauser derivative, built using the dish method with a bolt-on neck. I see no technical reason why classical guitars can't be built this way by professional builders. The traditional solera method is just that - traditional. The world continually moves on from old traditions as new techniques/tools/materials/ideas are developed. The owner of my first classical has tried it side-by-side with several solera-built traditional classical guitars and apparently there's quite a difference between them: mine is easier to play and sounds a lot better. I ,for one, plan to keep building them this way.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Fri Feb 19, 2010 5:23 pm
Steven Walters builds first class classical guitars with bolt on necks. Also very playable. However, there are differences, and a solera built classical can be built to play as easily as any other guitar. It's all in the geometry of the system, and the fine tuning of the fretboard. Also, in the classical world, tradition is a big item. It is changing some, with the lattice and double top guitars, but they represent only a very small percentage of the active, guitar playing, buyers.
Users browsing this forum: J De Rocher and 31 guests
